XnView MP 0.85
Moderators: XnTriq, xnview
XnView MP 0.85
Postby xnview » Tue Apr 04, 2017 2:39 pm
Please, don't post bugs or request in this topic!
You can download XnView MP 0.85 here:
Windows x32 ZIP version: http://download.xnview.com/XnViewMP-win.zip
Windows x32 SETUP version: http://download.xnview.com/XnViewMP-win.exe
    SHA256: C286FC416B1AA278DD8687B45457C44426B8D2EB355EEA775B0CBFD186360308
Windows x64 ZIP version: http://download.xnview.com/XnViewMP-win-x64.zip
Windows x64 SETUP version: http://download.xnview.com/XnViewMP-win-x64.exe
    SHA256: 829CD9820F275047216CEB7ACEC9736167A30F1B92BDA86C71F47FF1ADFD1A1B
Mac x64 TGZ version: http://download.xnview.com/XnViewMP-mac.tgz
Mac x64 DMG version: http://download.xnview.com/XnViewMP-mac.dmg
Linux TGZ version: http://download.xnview.com/XnViewMP-linux.tgz
Linux DEB version: http://download.xnview.com/XnViewMP-linux.deb
Linux x64 TGZ version: http://download.xnview.com/XnViewMP-linux-x64.tgz
Linux x64 DEB version: http://download.xnview.com/XnViewMP-linux-x64.deb
Changelog 0.85:
0114: [New] Create contact sheet
1052: [New] TWAIN 32bits support in 64bits
1082: [New] Shortcuts setting in 2 separate list
1087: [New] Template filename in Import&sort dialog - viewtopic.php?t=34729
1072: [New] Context menu of tree pane: Order of menu items - viewtopic.php?t=34688
1070: [New] UNC expand in folder tree - viewtopic.php?t=34673
1063: [New] Keep Histogram/grid/info state when view tab is closed - viewtopic.php?t=34641
1148: [New] Draw: Del key to remove item - viewtopic.php?t=35037
1040: [New] MacOSX drag&drop -> Move instead of Copy - viewtopic.php?t=34214
1159: [New] Read/Write settings in global settings dialog
1158: [New] Linux: copy and paste - viewtopic.php?t=35066
0490: [New] Filename in statusbar not elided - viewtopic.php?t=30717
1117: [New] Ask again message in dialog box - viewtopic.php?t=29221
1115: [New] useQtAV instead of videoMode setting
1114: [New] Icons for "Uncolored" and "Uncolored (Next image)" - viewtopic.php?t=34941
1141: [New] Shortcuts for page navigation - viewtopic.php?t=18514
1107: [New] Click on favorites star does nothing - viewtopic.php?t=34901
1097: [New] Menu entry "View»Info pane»Show" missing - viewtopic.php?t=24061
1095: [New] Custom filter - viewtopic.php?t=34778
0738: [New] Selection save/restore
1169: [Bug] Drag&Drop in file list copies file in detail view - viewtopic.php?f=62&t=35157
1168: [Bug] "Fullscreen" not disabled for non-image files - viewtopic.php?f=101&t=35003
1164: [Bug] Setting "Folder of Thumbnail database" is not kept - viewtopic.php?f=62&t=35151
1163: [Bug] PAM format - viewtopic.php?f=36&t=35132
1162: [Bug] Issues on HiDPi screen
1161: [Bug] Change timestamp: UI change when toggling checkbox - viewtopic.php?t=35086
1160: [Bug] Update catalogue from files causes heavy disk access - viewtopic.php?t=35052
0686: [Bug] Date problem - viewtopic.php?t=32019
1157: [Bug] Severe bug: photo overwritten without warning - viewtopic.php?t=35046
1156: [Bug] Linux: dot in folder name -> saveas bug - viewtopic.php?t=29099
0902: [Bug] Issues on Retina screen - viewtopic.php?t=27420
1155: [Bug] Resizing to large image fails silently - viewtopic.php?t=35060
1154: [Bug] Print -> Captions - viewtopic.php?t=33647
1153: [Bug] MacOS: Draw function generates unexpected crash & quits - viewtopic.php?t=35036
1152: [Bug] Search function - possible memory leak - viewtopic.php?t=32943
0641: [Bug] Sort by Aperture/Focal/Shutter - viewtopic.php?t=31496
1151: [Bug] Category Set: Can't remove category - viewtopic.php?t=30823
1150: [Bug] Copy & Paste of folder pastes as subfolder - viewtopic.php?t=35020
1149: [Bug] Tiff compression - viewtopic.php?t=32252
1103: [Bug] MacOSX: delete folder - not moved in trash can
1102: [Bug] Setup wizard - XnView folder by default
1146: [Bug] Batch convert, Same filename in hotfolder unrecognized after first run - viewtopic.php?t=35012
1145: [Bug] USB stick not detected - viewtopic.php?t=29313
1144: [Bug] Draw tool: No consecutive text drawing - viewtopic.php?t=34152
1143: [Bug] Page Numbers wrong when Thumb Printout - viewtopic.php?t=34396
0950: [Bug] Different ratio X/Y - viewtopic.php?t=33725
1122: [Bug] Browser: Change filter doesn't update statusbar - viewtopic.php?t=35026
1140: [Bug] Batch rename thumbnail enlarges constantly - viewtopic.php?t=32528
1139: [Bug] Wait cursor in "JPG lossless" warning message box - viewtopic.php?t=34994
1138: [Bug] Format colors isn't working - viewtopic.php?t=33870
0890: [Bug] Pan tool problem - viewtopic.php?t=33349
1137: [Bug] Set selection ratio - viewtopic.php?t=33671
1136: [Bug] Changing theme doesn't update XnView - viewtopic.php?t=34959
1135: [Bug] 'Auto play (video)' option doesn't affect current tab - viewtopic.php?t=34887
1134: [Bug] Updater logic - version compare logic typo - viewtopic.php?t=34574
1133: [Bug] Shortcut Alt+Enter doesn't open properties - viewtopic.php?t=34613
1132: [Bug] Disable dropdown while in crop mode - viewtopic.php?t=34946
0157: [Bug] Drag&drop in GPS pane - viewtopic.php?t=28982
1131: [Bug] Cropping is a bit off - viewtopic.php?t=34911
1130: [Bug] Kolor Crash reporter: Upload enabled after deletion - viewtopic.php?t=34988
1129: [Bug] Kolor Crash reporter: Upload button remains enabled - viewtopic.php?t=34766
1128: [Bug] Deleting files in fullscreen mode deleted all folders - viewtopic.php?t=29628
1127: [Bug] Categories on folder - viewtopic.php?t=33643
1126: [Bug] Category filter & base path - viewtopic.php?t=34881
1125: [Bug] Selection: 'W' key doesn't always swap - viewtopic.php?t=34984
1124: [Bug] No backup for lossless operations - viewtopic.php?t=34957
1123: [Bug] JPEG lossless cropping is completely off - viewtopic.php?t=34957
1121: [Bug] Some context menu items unavailable after making copy - viewtopic.php?t=34908
1118: [Bug] Selection: Swapping h/w doesn't update status - viewtopic.php?t=34983
1120: [Bug] Many disk accesses when canceling ITPC/IIM dialog - viewtopic.php?t=34992
1119: [Bug] Batch convert: ZIP files without .zip extension - viewtopic.php?t=34999
1116: [Bug] Folder filter should update when we change the folder - viewtopic.php?t=34915
1113: [Bug] Incorrect volume reading after restart when vol at 0 - viewtopic.php?t=34889
1112: [Bug] Category filter: Deselecting doesn't deselect children - viewtopic.php?t=34770
1111: [Bug] Searching twice returns no results - viewtopic.php?t=34920
1110: [Bug] Viewer: Selection lost when moving selection - viewtopic.php?t=34860
1109: [Bug] Tagging files by checking them causes strange behavior - viewtopic.php?t=34918
1105: [Bug] Always "Folder" after hiding data pane - posting.php?p=138489
1108: [Bug] # of object(s) selected doesn't clear properly - viewtopic.php?t=34917
1106: [Bug] .XnViewSort never shown - viewtopic.php?t=34906
1104: [Bug] Toolbar Command "Show" gone after adding and removing - viewtopic.php?t=34885
1101: [Bug] View»Data pane»Show unhides Folder tree - viewtopic.php?t=34868
1077: [Bug] Titlebar no longer hidden when switching mode - viewtopic.php?t=34711
1100: [Bug] ":\ not allowed in windows filename - viewtopic.php?t=29700
1099: [Bug] Viewer: "Page" in context menu not disabled - viewtopic.php?t=34864
1010: [Bug] Tree & browser sync issue - viewtopic.php?t=34016
1011: [Bug] Tree order - viewtopic.php?t=34017
1094: [Bug] Capture is not capturing the cursor - viewtopic.php?t=34578
1073: [Bug] Folder tree not updated when deleting folder - viewtopic.php?t=34687
1093: [Bug] "Show Alpha" doesn't toggle using "M" key - viewtopic.php?t=34466
1092: [Bug] can't remember auto image size in fullscreen - viewtopic.php?t=34747
1091: [Bug] Binary image zoom-in glitch - viewtopic.php?t=34746
1090: [Bug] Rating & Label not export in XMP Sidecar automatically - viewtopic.php?t=34728
1089: [Bug] Check for orphaned files/directories can wipe catalog info - viewtopic.php?t=30490
1088: [Bug] Category/rating cannot be used in create file listing
1086: [Bug] Fullscreen - Crazy Info Panel - viewtopic.php?t=34756
1085: [Bug] Browser: Filter by»Custom always checked - viewtopic.php?t=34769
0958: [Bug] Grid always selected in crop mode - viewtopic.php?t=33727
1084: [Bug] Fullscreen - No Crop Menu - viewtopic.php?t=34755
1080: [Bug] Switching mode: Only middle-doubleclick switches - viewtopic.php?t=34692
1078: [Bug] Copy to/Move to: Double-click on folder triggers - viewtopic.php?p=138018
1075: [Bug] Settings not saved in argument INI - viewtopic.php?t=34681
1074: [Bug] Export - Quality value not visible for WebP - viewtopic.php?t=34713
1071: [Bug] 'Tag' filter show always all files - viewtopic.php?t=34677
1069: [Bug] Moving files messes up categories & base path- viewtopic.php?t=34643
1065: [Bug] Crash when zooming out small image using grid - viewtopic.php?t=34656
1066: [Bug] .JP_ image deleted in JPEG lossless transformation - viewtopic.php?t=34660
1064: [Bug] File size&name not updated in statusbar - viewtopic.php?t=34646
1062: [Bug] Rename dialog template - viewtopic.php?t=34627
1061: [Bug] Video play/pause - viewtopic.php?t=34614
1060: [Bug] Filelist: 2 slashes - viewtopic.php?t=34619
Serezha
Re: XnView MP 0.85
Postby Serezha » Tue Apr 04, 2017 6:52 pm
Hello! After install Windows x64 SETUP version, programm not run, because not found icudt57.dll, icuin57.dll and icuuc57.dll
Re: XnView MP 0.85
Postby xnview » Tue Apr 04, 2017 7:26 pm
Serezha wrote:Hello! After install Windows x64 SETUP version, programm not run, because not found icudt57.dll, icuin57.dll and icuuc57.dll
Please try to download it again
Moderator & Librarian
Re: XnView MP 0.85
Postby XnTriq » Tue Apr 04, 2017 7:45 pm
:-D THANKS @ Pierre, Helmut and all the forum members who contributed with their input/feedback during the beta-testing phase!
Re: XnView MP 0.85
Postby helmut » Wed Apr 05, 2017 8:22 am
Thank you for the new 0.85, Pierre. It's good to see that focus was set on quality and to see the long list of fixed bugs that no longer bother users. :)
Quite a number of people helped in reporting problems, reproducing, and retesting them. Special thanks to vertigo, m.Th., CameronD, and HanVroon for their support and effort!
VictorVG
Re: XnView MP 0.85
Postby VictorVG » Wed Apr 05, 2017 10:38 am
Re: XnView MP 0.85
Postby XnTriq » Wed Apr 05, 2017 3:30 pm
xnview wrote:1115: [New] useQtAV instead of videoMode setting
useInternalVideoPlayer replaces useQtAV and videoMode in the final release:
xnview (0.85: New Line Found Inside .ini) wrote:
Erixx haxx wrote:
xnview wrote:videomode is no more used
OK, Thanks
I think useQTAV=boolean makes more sense here.
Will be "useInternalVideoPlayer" (> 0.85 beta 2)
Dreamer
Re: XnView MP 0.85
Postby Dreamer » Wed Apr 05, 2017 6:37 pm
Thank you, Pierre.
Dreamer
cch44
Re: XnView MP 0.85
Postby cch44 » Thu Apr 06, 2017 6:49 am
Merci Pierre pour cette nouvelle version.
Bonne journée
Gérard 91
Re: XnView MP 0.85
Postby Gérard 91 » Thu Apr 06, 2017 10:27 am
Hi
Quite a long list of issues and improvements !
Great job
Thanks Pierre and every one contributing to this more and more qualitative software
Gérard
toyotadesigner
Re: XnView MP 0.85
Postby toyotadesigner » Thu Apr 06, 2017 11:48 am
Wow. This version (Mac OS X) is a lot more responsive in the file list, the display of full images, the drag and drop function, the full size window display and the refresh function is working again. Refreshing the thumbnails or building a new one from a large saved TIFF file is also a lot faster. In addition it appears to me that the new version needs even less memory than the previous one.
Thanks a lot to the developer team!
hobbyists discuss new camera features
photographers discuss new software
masters discuss light
dietmar
Re: XnView MP 0.85
Postby dietmar » Sat Apr 08, 2017 10:58 am
xnview wrote:Linux x64 DEB version: http://download.xnview.com/XnViewMP-linux-x64.deb
Pierre,
this DEB installs 0.85 but says it's installing 0.84.
Thanks
Dietmar
Octopuss
Re: XnView MP 0.85
Postby Octopuss » Fri Apr 14, 2017 6:44 am
Whoa, what a changelog.
Return to “MP - General Support”
Who is online
Users browsing this forum: No registered users and 1 guest
