MacOS: Unable to save metadata
hajes
Post by hajes »
right click on JPEG > Edit IPTC/XMP > add keywords, description > Save Template
all seems ok but nothing is saved
by next image load template and is empty
It is a brand new Apple MacBook Pro 13" (2016), Mac OS X 10.12.4
it used to work on my old Apple MBP 17" (2011)
bug or some permission problems?
Regards
David
Re: MacOS: Unable to save metadata
Sorry but i can't reproduce on MacOSX 10.12
hajes
Post by hajes »
uninstalled
installed "brew install xnviewmp"
it works
something damaged by DMG installation or corrupted file perhaps
hajes wrote:uninstalled
it works
Thank you for reporting back, hajes. Good to read that a reinstallation did fix the problem.
:arrow: Closed
