0.86: Custom selection ratio presets not available in main menu
  1. Open an image in the viewer.
  2. Go to EditCrop... to enter “crop mode”.
  3. Click on the ... button on the crop toolbar to enter the Crop size... dialog.
  4. Click on the New... button.
  5. Create a new preset (Width 9 | Height 16 | ratio) and save it by clicking on the OK button.
    • A new file named CropSize.xml is created.
    • The newly specified preset 9:16 (0.56) is added to the list in the drop-down menu on the crop toolbar, but it is missing in EditSet selection ratio. :bug:
[color=green]CropSize.xml[/color] wrote:
<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE crop_size><crop_size version="1.0">
    <array>
        <item label="" width="1" height="1" unit="ratio" ratio="0" visible="yes"/>
        <item label="" width="2" height="1" unit="ratio" ratio="0" visible="yes"/>
        <item label="" width="3" height="2" unit="ratio" ratio="0" visible="yes"/>
        <item label="" width="4" height="3" unit="ratio" ratio="0" visible="yes"/>
        <item label="" width="5" height="3" unit="ratio" ratio="0" visible="yes"/>
        <item label="" width="5" height="4" unit="ratio" ratio="0" visible="yes"/>
        <item label="" width="7" height="5" unit="ratio" ratio="0" visible="yes"/>
        <item label="" width="9" height="7" unit="ratio" ratio="0" visible="yes"/>
        <item label="12:10 (1.2)" width="12" height="10" unit="ratio" ratio="0" visible="yes"/>
        <item label="16:9 (1.78)" width="16" height="9" unit="ratio" ratio="0" visible="yes"/>
        <item label="16:10 (1.6)" width="16" height="10" unit="ratio" ratio="0" visible="yes"/>
        <item label="A4, A3, ... (1.41)" width="141" height="100" unit="ratio" ratio="1.41" visible="yes"/>
        <item label="US Letter (1.29)" width="129" height="100" unit="ratio" ratio="1.29" visible="yes"/>
        <item label="Cinema 1 (1.85)" width="185" height="100" unit="ratio" ratio="1.85" visible="yes"/>
        <item label="Cinema 2 (2.35)" width="235" height="100" unit="ratio" ratio="2.35" visible="yes"/>
        <item label="" width="80" height="60" unit="cm" ratio="0" visible="yes"/>
        <item label="" width="90" height="60" unit="cm" ratio="0" visible="yes"/>
        <item label="" width="127" height="95" unit="cm" ratio="0" visible="yes"/>
        <item label="" width="130" height="100" unit="cm" ratio="0" visible="yes"/>
        <item label="" width="152" height="102" unit="cm" ratio="0" visible="yes"/>
        <item label="" width="152" height="114" unit="cm" ratio="0" visible="yes"/>
        <item label="" width="178" height="127" unit="cm" ratio="0" visible="yes"/>
        <item label="" width="180" height="130" unit="cm" ratio="0" visible="yes"/>
        <item label="" width="203" height="152" unit="cm" ratio="0" visible="yes"/>
        <item label="" width="212" height="152" unit="cm" ratio="0" visible="yes"/>
        <item label="" width="228" height="152" unit="cm" ratio="0" visible="yes"/>
        <item label="27.9x21.6 [US Letter]" width="279" height="216" unit="cm" ratio="0" visible="yes"/>
        <item label="" width="297" height="210" unit="cm" ratio="0" visible="yes"/>
        <item label="" width="305" height="203" unit="cm" ratio="0" visible="yes"/>
        <item label="" width="457" height="305" unit="cm" ratio="0" visible="yes"/>
        <item label="" width="600" height="400" unit="cm" ratio="0" visible="yes"/>
        <item label="" width="762" height="508" unit="cm" ratio="0" visible="yes"/>
        <item label="" width="800" height="600" unit="cm" ratio="0" visible="yes"/>
        <item label="" width="9" height="16" unit="ratio" ratio="0" visible="yes"/>
    </array>
</crop_size>
Re: [0.86] Custom selection ratio presets not available in main menu
I've just reproduced the problem and can confirm the observed behaviour.
To me it looks as if the list of crop profiles is one list and the lists behind selection ratio and/or set selection size are seperate lists. So I wonder whether this is a bug or just the way it is currently designed (which should be discussed and changed). What do you think?
I see what you mean: The drop-down menu on the crop toolbar combines all values from both the Set selection size and Set selection ratio from the Edit menu (plus custom presets).
:arrow: Closed
