I'm using the new checkbox option "write hierarchical keywords" in (Tools, Settings, Metadata)
- (excellent !) -
When the box is unchecked, I can see this line in XnView.ini :
writeHierarchical=false
But at startup, I think xnviewmp doesn't read this line, and the box is checked again ...
the line in .ini file becomes : writeHierarchical=true
Expected : When the box is not checked, restarting xnview should not change this option.
And the GUI text for this option could be "Write hierarchical IPTC keywords"
[solved]0.87 beta 2. option write hierarchical modified at restart (& beta 3)
Catalogage avec XnviewMP :
Re: 0.87 beta 2. option write hierarchical modified at restart
Still the same behaviour in v0.87 beta3 ...
... seems not fixed
... seems not fixed
[solved] 0.87 beta 2. option write hierarchical modified at restart (& beta 3)
solved
Thanks
Thanks
