XnView: MP 0.87 - 64 bit
OS: Windows 10 Pro 64bit
Ctrl-C doesn't copy images in Viewer mode in 0.87 MP like it did in previous versions.
Effect: Instead of copying, it clears your current clipboard information.
1. Select an image and go into Viewer mode.
2. Press Ctrl-C.
3. Try to paste anywhere, e.g. File explorer/Browser (uploading image)
Actual behaviour (bug): When you paste nothing happens, it doesn't copy the image or give you the file path if you're uploading the image. Instead it will clear your clipboard.
Expected behaviour: Copy image or give you file path if you're uploading the image.
0.87: Ctrl-C doesn't copy in Viewer Mode
Re: 0.87: Ctrl-C doesn't copy in Viewer Mode
O.k., thank you, I can also reproduce the problem. Issue 1301 is fixed in next version.
It's a problem with this fix
Actually the copy function does work, it is the paste command that appears to be broken in v0.87.
When copying anything in View mode, the Edit menu entry "Paste" remains grayed out and you cannot paste the copied content anywhere in XnView. However switching (ALT+TAB) to any other image application, the copied content from XnView can be pasted there from the clipboard.
This problem is supposed to be fixed in XnView MP 0.88. Please check and confirm the bug fix here.
I confirm that this problem is fixed in XnView MP 0.88. Thank you.
