0.88: All details on info pane are missing while Fullscreen preview is active [solved]
Jochen S.
Post by Jochen S. »
XnView: MP 0.88 64 bit
OS: Linux Mint 18.1 64 bit
I have two monitors and configured XnView to use both (Options > View > Fullscreen > "Dual monitor: use second monitor" is checked)
While Fullscreen is not active I can select any image and its details are shown on the info pane in tabs like "Properties", "Histogram", "EXIF", "IPTC", "XMP" and "ExifTool". (which is fine and should just explain what feature I'm talking about)
To reproduce / Actual behaviour (bug):
When I activate Fullscreen (F11) while an image is selected then the image is shown on the second monitor ( :D ) but ALL tabs on the info pane disappear ( :bug: ). If another image is selected while Fullscreen is already active then ONLY the "Properties" tab is shown again ( :bug: ), the other tabs are not shown until Fullscreen is disabled again.
Effect: I can not view all the details tabs on the info pane while Fullscreen is active
Expected behaviour:
The windows version shows all configured tabs on the info pane regardless Fullscreen preview is active or not. I'd expect this behaviour from XnView MP too.
Re: 0.88: All details on info pane are missing while Fullscreen preview is active
:bugconfirmed: Thanks to your detailed description I can reproduce the problem. This problem exists in previous version too
Jochen S.
Post by Jochen S. »
And it still exists in 0.89 :wink:
This problem is supposed to be fixed in XnView MP 0.91. Please check and confirm the bug fix here.
Jochen S.
Post by Jochen S. »
There is no linux version of 0.91 available yet so I can't test. You do not need to build one for me since I would prefer not to install beta versions on my system.
Jochen S.
Solved: 0.88: All details on info pane are missing while Fullscreen preview is active
Post by Jochen S. »
Solved in 0.92
