0.89: Ctrl+Right Click unselects the image
arspr
Post by arspr »
XnView: MP 0.89 64 bit
OS: Windows 64bit
Some of the buggy behaviours of the new Ctrl+Right Click feature...
If you have a selected image and then you Ctrl+Right Click over it, you unselect it and therefore no context menu is shown.
(OTOH if you only Right Click, it isn't unselected and XnView context menu is shown).
Effect: Incoherent and unexpected behaviour.
1. Select an image. (Left click on it)
2. Now Ctrl + Right Click on it.
3. (Repeat and compare what happens if you just Right Click on it).
Re: 0.89: Ctrl+Right Click unselects the image
Same behavior, the current thumbnail is always selected.
arspr
Post by arspr »
xnview wrote:Same behavior, the current thumbnail is always selected.
Yes... because the behaviour seems linked to the kind of view you've selected...
Thumbnails: No bug, Ctrl + Right Click does not unselect your current image.
Details: Bug, Ctrl + Right Click unselects your current image...
This problem is supposed to be fixed in XnView MP 0.91. Please check and confirm the bug fix here.
arspr
Post by arspr »
Fixed!!! (0.91b4)
