0.85: Create thumbnails for the whole folder
karnak
Post by karnak »
XnView MP Windows
Version 0.89 64bits
Windows 10 Pro x64
Version 1709 Build 16229.125
If you set Settings > Thumbnail > Create thumbnails for the whole folder to FALSE
XnView starts high disk activity especially:
C:\$LogFile (NTFS Volume Log) ... Write(B/sec) 1,800,000
C:\Users\<user>\AppData\Roaming\XnViewMP\XnView.db ... Write(B/sec) 1,700,000
The above data is from Resource Monitor.
This behavior can disrupt other applications work, like rendering applications.
Re: 0.85: Create thumbnails for the whole folder
your folder contains a lot of files? no problem if this setting is TRUE?
karnak
Post by karnak »
No issue with Create thumbnails for the whole folder set to TRUE.
I just did more tests and found something interesting that is not related to the number of files in the folder.
I have an empty folder with just one TXT file and Create thumbnails for the whole folder set to FALSE.
If I set
Settings > File list > Custom Filter > Text > Visible to TRUE
Settings > File list > Custom Filter > Text > Show as Thumbnail to FALSE
Settings > File list > Custom Filter > Text > Show in preview to FALSE
I have the high disk activity issue.
If I set
Settings > File list > Custom Filter > Text > Show as Thumbnail to TRUE
I don't have the high disk activity issue.
i can't reproduce, please send me your .ini
karnak
Post by karnak »
I sent you a PM with the .ini link, thank you.
I'll also check if I can reproduce the issue with the same .ini on a laptop and report back.
karnak wrote:I sent you a PM with the .ini link, thank you.
thanks, i can reproduce with your .ini
See issue for current status and some details. I'll post here once the problem has been fixed.
karnak
Post by karnak »
Thank you, I was also able to reproduce on a different computer with my .ini and a new one.
I see that you have already fixed it and it is in testing phase, nice work.
This problem is supposed to be fixed in XnView MP 0.90. Please check and confirm the bug fix here.
karnak
Post by karnak »
I confirm that the issue is fixed (0.90 beta 1).
Thank you!
