Split images: cannot zoom
m.Th.
Post by m.Th. »
In Split Images module, one cannot zoom.
Please implement the zoom primitives - Zoom In, Out, 100%, Fit - like in Create Contact Sheet module (Preview tab).
m. Th.
Re: Split images: cannot zoom
you can zoom with mouse wheel. You means adding buttons?
m.Th.
Post by m.Th. »
xnview wrote:you can zoom with mouse wheel. You means adding buttons?
Sure. Mouse wheel = very good but not discoverable.
Ok, perhaps is better to put a text - something like „Use the mouse wheel to zoom” - but having buttons for 100% Zoom and Zoom to Fit is necessary.
m. Th.
This problem is supposed to be fixed in XnView MP 0.90. Please check and confirm the bug fix here.
m.Th.
Post by m.Th. »
xnview wrote:This problem is supposed to be fixed in XnView MP 0.90. Please check and confirm the bug fix here.
Fixed
m. Th.
