XnViewMP 0.90 - Batch convert -> action -> preview window does not update
masterjp
Post by masterjp »
I want to convert many picture files with batch conversion function.
I use different settings in the action list.
The "before" preview window show me the picture.
If I switch to "after" window, I will not see a preview.
I must click on update preview window button to see something.
It would be nice to get an updated preview picture, if I switch from "before" window to "after" window.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
Re: XnViewMP 0.90 - Batch convert -> action -> preview window does not update
Sometimes in order to see a preview it is necessary to click on the small arrow symbol to the left of the preview window, I think...
I'm not sure why sometimes a preview is displayed automatically, and sometimes it is necessary to do that. :?:
masterjp
Post by masterjp »
@cday: Thank you for your help.
It is a bit weird that when you scroll through the preview windows, you can see the preview, but unfortunately not at the start of the batch conversion.
I think the "before" and "after" switch do not refresh the preview.
This problem is supposed to be fixed in XnView MP 0.91. Please check and confirm the bug fix here.
masterjp
Post by masterjp »
The problem is not completely solved.
If I start a batch conversion, I will see the "output" tab by default.
If I switch to "Action" tab, then the preview won't show a preview picture of the after" tab window.
If I switch to the next picture, I will get a correct "after" preview.
masterjp wrote: Fri Jun 22, 2018 2:17 pm The problem is not completely solved.
ok i'll fix it
This problem is supposed to be fixed in XnView MP 0.91 beta 2. Please check and confirm the bug fix here.
masterjp
Post by masterjp »
I see the "after" preview now. It works fine. Thank you.
