Adding music into Slideshow
sasko1
Post by sasko1 »
Not sure if this request was already here (I couldn't find anything) but was thinking if it is possible to be available.
So if you make slideshow of image, just to be able to add mp3 file to play along the slideshow (or this feature already exists?).
Thanks
m.Th.
Re: Adding music into Slideshow
Post by m.Th. »
I second this!!
It is one of the most sought features for the slide shows. All (?) commercial programs have this implemented, some of them having an entire playlist for this purpose.
It is quite simple to implement - XnView MP is supposed to play sounds already.
The sound (music) should be played in background.
Add also at the end of the music a "nnn" seconds delay. (nnn < 9999 for example. Sometimes the silence can be put as much as 15 minutes - common in public place like restaurants etc.)
m. Th.
This problem is supposed to be fixed in XnView MP 0.91. Please check and confirm the bug fix here.
m.Th.
Post by m.Th. »
1. The sound isn't heard.
2. The sound is looping? Can you add a delay before loops?
m. Th.
m.Th. wrote: Fri Jun 08, 2018 7:36 am 1. The sound isn't heard.
ok, right, will be fixed
currently no looping
m.Th.
Post by m.Th. »
fixed in 0.91b2
m. Th.
