Metadata is not saved in single-image mode
SergSA
Post by SergSA »
If you save metadata in the single image view mode, they are not actually saved.
If you go to the browser mode, you can see that the metadata is not preserved thereafter.
Re: Metadata is not saved in single-image mode
you means IPTC?
SergSA
Post by SergSA »
xnview wrote: Fri Mar 15, 2019 7:47 amyou means IPTC?
Yes.
you need to save image to save metadata
SergSA
Post by SergSA »
xnview wrote: Fri Mar 15, 2019 9:51 am you need to save image to save metadata
Thank.
So in this mode, it is better not for me to make an IPTc, since then the modification date of the file will change.
you can change the settings
Post by michel038 »
Settings : General, File operations, ...
Pierre, is there a quality loss when saving image this way ?
so, it would be better to avoid using this method ..
michel038 wrote: Fri Mar 15, 2019 12:48 pm Pierre, is there a quality loss when saving image this way ?
you recompress the data, so for JPEG yes.
Or perhaps i can a 'Write' button?
Post by michel038 »
Yes, a "Write metadata" button.
This problem is supposed to be fixed in XnView MP 0.94. Please check and confirm the bug fix here.
Post by michel038 »
Solved :D
"Write" button is ok
But what is the use of "Apply" button ?
CameronD
Post by CameronD »
michel038 wrote: Tue Sep 17, 2019 9:28 pm But what is the use of "Apply" button ?
A good question. I have edited this reply, since my original comment was wrong.
"Apply" saved your changes in the program's internal copy of the image metadata. You can even view one image next or previous and the changes are still there, but not yet saved to disc until you select "save". There is no warning if you do not save.
I think it should be changed to either
  • remove the "apply" button, or
  • set the "edited" state so the user can be warned
I thought it might apply changes on the options tab, but these seem to be applied immediately, even if you press "cancel"
