how to replace/overwrite file?
sikorumbe
Post by sikorumbe »
Hi Guys,
was just wondering if there is "replace/overwrite" file dialog when xnview detecting the same file ?
Rather than just create another one and add "copy" into the file name?
Thank you.
Re: how to replace/overwrite file?
yes you have a replace dialog when the file exists
sikorumbe
Post by sikorumbe »
Hi
I'm Sorry how to get the replace dialog to appear again?
Currently, it seems xnview MP automatically rename the file with "copy"
Thank you.
how do you try to replace file?
Chrissurf
Post by Chrissurf »
sikorumbe wrote: Thu Apr 25, 2019 2:18 pm Hi
Thank you.
I have the same Problem.
When i copy Files and past form Folder 1 to folder 2 to find the add files in folder 2 (merge it) it only copy the files.
Normal in Finder or Explorer it ask me would like to replace the file?
In XnView MP Version 0.93.1 it only make a copy with the extension name "... - Copy.JPG"
In the Settings "General -> File Operations" i have disable "add copy for duplicates", but it always copy the File / Pictures.
For example form "DSC04812.JPG" to the name "DSC04812 - Copy.JPG"
Please fix it.
Many thanks
Dear Christian
when you drag&drop or Ctrl+C/Ctrl+V of a file in same folder, 'copy - ' will be added, no replace dialog is shown...
sikorumbe
Post by sikorumbe »
So is there a way to replace existing file (without having adding _copy.jpg) ?
Kindly guide me.
Thank you.
currently no way
Steel Rat
Post by Steel Rat »
Up until now I had been exclusively using classic XNView, which does ask when copying. This post is 4 years old, are there any plans to add this functionality? Without it, MP is not nearly as useful for file operations.
Thanks!
Steel Rat wrote: Sat Dec 23, 2023 2:24 am Up until now I had been exclusively using classic XNView, which does ask when copying. This post is 4 years old, are there any plans to add this functionality? Without it, MP is not nearly as useful for file operations.
What do you want to do?
xnview wrote: Thu Dec 28, 2023 9:33 am What do you want to do?
standard behaviour of file managers
to reproduce
0. have 2 files with the same names in 2 folders
1. CTRL+C in one folder
2. CTRL+V in another folder
file will be copied and renamed without any warnings, so now there are 2 files in target folder
expected behaviour
Overwrite dialog shall appear
Related
This problem is supposed to be fixed in XnView MP 1.6.4. Please check and confirm the bug fix here.
fixed in 164
