File export dialog - webp - shrink to filesize does not work
masterjp
Post by masterjp »
The XnViewMP file export to webp format with limited filesize (e.g. set to 100 KB) does not work.
Maybe you can remove it from the file export dialog or hide it, because it actually does not work?
You told me in the past, that it is a problem of the webp library, which does not correctly support it.
PC: Intel 8700k + Asus Z370-F + 48 GB RAM Corsair+G.Skill + Asus RTX 3050 OC + Samsung SSD
GFX: XnViewMP 1.9.8 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.11
Re: File export dialog - webp - shrink to filesize does not work
This problem is supposed to be fixed in XnView MP 0.94. Please check and confirm the bug fix here.
masterjp
Post by masterjp »
Wonderful, it works now!
Sometimes the webp file size is next to the selected filesize, but totally okay.
I select 200 kb and get a 195 kb file. That is okay.
