XnViewMP 0.94b1 - Browser behaviour and renaming directories
masterjp
Post by masterjp »
Since the latest beta version, I have noticed various changes in the operation, where I wanted to ask if they are wanted or possibly new errors.
1. Moving folders
Previously you could move directories in the left treeview structure by drag and drop.
Now you can only move directories from the right pane into the treeview structure. Is that wanted?
2. Renaming folders
If you select a folder in the treeview structure, you can select the entry "rename" in the context menu. This one does not work.
The shortcut "F2" does not work, too. Did you disabled it? It was very useful.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
Re: XnViewMP 0.94b1 - Browser behaviour and renaming directories
a bug...
beta 2 is available...
masterjp
Post by masterjp »
Perfect! Thank you. The bug is fixed.
