0.94 beta #3 - Batch conversion - output path problem
masterjp
Post by masterjp »
I tried a batch conversion with XnViewMP and selected the "..." button in the dialog to choose the output directory (H:).
XnViewMP uses "H:" in the textbox.
This does not work, because XnViewMP needs a "H:\" path to correctly do the batch conversion.
Otherwise the batch conversion will fail. Maybe you can add a check algorithm, which will add a "\" if the path is a root directory of a drive.
That would be perfect.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
ckit
Re: 0.94 beta #3 - Batch conversion - output path problem
Post by ckit »
Confirmed with D: on my Samsung 850 EVO drive
