Open second image has an issue with fullscreen mode
gm649
Post by gm649 »
Hi ,first thanks for Xnviewmp
I want to report an issue :
Xnviewmp always open second image in "viewer window mode" (not fullscreen viewer) , although i set default mode is "fullscreen viewer"
How to reproduce :
- set maximumtab = 1
- option => general => mode when starting a file : fullscreen - viewer
-open a image file with xnview mp , it works fine ,image open in fullscreen
-leave that xnview mp window open ,and open another image file in windows explorer,which bring the image to xnviewmp => xnviewmp open this image in "window viewer mode" , not fullscreen mode (it should be fullscreen like i set in settings )
Sorry for bad English
Thanks
Re: Open second image has an issue with fullscreen mode
gm649
Post by gm649 »
xnview wrote: Wed Nov 27, 2019 2:54 pm :bugconfirmed: Thanks to your detailed description I can reproduce
Thank you very much , i 'm very anxious to see the fixed version (beta is fine too)
I really appreciate it
gm649
Post by gm649 »
xnview wrote: Fri Mar 06, 2020 7:51 am See issue for current status and some details.
Thank you very much , im very appreciate it
i will try it
gm649
Post by gm649 »
xnview wrote: Sat Mar 21, 2020 9:15 am This problem is supposed to be fixed in XnView MP 0.96. Please check and confirm the bug fix here.
the bug was fixed , work like a charm now
thank you very much
