No more access to the end of Exiftool data (Pentax?)
Markorki
Post by Markorki »
Hello !
I'll try to use the template ;-)
_____________________________________________________
Subject: 0.94.1: <no angle exiftool data >
XnView: MP 0.94.1 - 64 bit
OS: Linux 64bit
Two "Angles" , Pitch angle and Roll angle, are located in the exiftool data after 2 groups of values, "AE metering segments " and "Flash metering segments", but these 2 groups are very long and seem to impair acces to the following data .
This bug was already present in 0.94, but probably not in 0.93 (not sure, I don't use this feature so often)
Effect: Cannot correct pictures taken not perfectly horizontal or vertical when shooting because I don't know the value of the rotation angle to apply.
1. select a picture
2. select Information tab/Exiftool tab
3. look for "Pitch angle" : you don't find it
Actual behaviour (bug): Display of parameters ends after "AE metering segments " and "Flash metering segments" parameters.
Expected behaviour: Display "Pitch angle" and "Roll angle", at bout 90% of the list.
______________________________________________________
I suspected exiftool could have been modified by an update, but I tried this in a terminal:
marc@PC-markorki$ exiftool -h MM_2019-02-17_09-57-41_P-K50__008629_0r.jpg | grep Angle
<tr><td>Roll Angle</td><td>1</td></tr>
<tr><td>Pitch Angle</td><td>7</td></tr>
So, the two parameters are still available through Exiftool command line.
But the same command where you replace "grep Angle" by "grep Segments" delivers a very long output.
If you need a Pentax K5O picture : http://sebmortum.free.fr/images_publiqu ... 6750_0.jpg
Dommage, l'était sympa cette planète ;-(
Re: No more access to the end of Exiftool data (Pentax?)
This problem is supposed to be fixed in XnView MP 0.94.2. Please check and confirm the bug fix here.
Markorki
Post by Markorki »
it's ok for me, bug 0001692 fixed in 0.94.2 : the angles in my transmitted picture are -45 (roll) and -26 (pitch) ;-)
so long, and happy new year !
