Naming a search does not work
nji9
Post by nji9 »
Opening the search dialog and entering a search name (+)
doesn't take that name.
Re: Naming a search does not work
'use regexp' is enabled?
nji9
Post by nji9 »
Doesn't work both ways.
BTW:
What has 'use regexp' to do with naming a search?
RegExp is a method to search
Without it enabled, no problem to search a filename with +
Do you use catalog?
nji9
Post by nji9 »
No, it seems there is a misunderstanding between us:
First I pop up the search dialog.
Then "Add >>>" some kind of condition.
Then want to give/ to save that search a name (Green button "+" = "Save current search").
I dialog pops to enter a name.
Do it.
==> NOT saved.
This problem is supposed to be fixed in XnView MP 0.96.3. Please check and confirm the bug fix here.
nji9
Post by nji9 »
Bug is gone :D
