Subject: 0.96.2 : file label "file size" not displayed
gfxfr
Post by gfxfr »
Subject: 0.96.2 : file label "file size" no longer displayed, is empty
XnView: MP 0.96.2 - 64 bit
OS: Windows - 64bit
When browsing with thumbnail+ label display, and with "file size" added in labels list (parameters -> explorer -> thumbnails -> labels), the Size labels are not displayed at all (for any kind of file).
Note : it was working with previous versions of the software
Effect: display glitch
1. Add "file size" to thumbnails labels
2. set display to thumbnail + labels
Actual behaviour (bug): File size is not displayed :bug:
Expected behaviour: file size is displayed
Re: Subject: 0.96.2 : file label "file size" not displayed
yes a known issue
gfxfr
Post by gfxfr »
Thx you
(sorry the search engine refuse requests about "file" or "size" words, so i can't properly check if it's duplicate, sorry for the inconvenience)
This problem is supposed to be fixed in XnView MP 0.96.3. Please check and confirm the bug fix here.
gfxfr
Post by gfxfr »
Fixed 👍
thx you
