Operators for rating filtering
Gwenael Q.
Post by Gwenael Q. »
I must be missing something very obvious :
In the Filter Drop-down menu, I can see the operators for rating filtering but none is selected and I can not select one like it is shown here : viewtopic.php?t=30071#p119978.
Any tip ?
XnviewMP 0.96.2 x64 on windows 8.1 x64
Thank you for listening
Re: Operators for rating filtering
could you post a screenshot?
Gwenael Q.
I would like to activate the "≤", "=" or "≥" icons :-(
Xnview0.92.6-Rating filtering operators.png (10.98 KiB) Viewed 2666 times
Thank you
On windows 10, the selected icon is more visible. See issue for current status and some details.
This problem is supposed to be fixed in XnView MP 0.96.3. Please check and confirm the bug fix here.
Gwenael Q.
Bug fixed !
Thank you.
0.96.3 x64 on windows 8.1 x64
