0.96.2 - search dialog : save command missing [Solved]
Gwenael Q.
Post by Gwenael Q. »
Sorry if i missed something obvious but I am not able to save the current search.
My interface is not the one illustrated here : https://orchisere.pagesperso-orange.fr/ ... mp.htm#11R fig.59:
Save search expected interface.PNG (3.66 KiB) Viewed 1909 times
but this one :
Save search incomplete interface.PNG (2.89 KiB) Viewed 1909 times
the save button is missing....
Thank you for listening
xnviewMP 0.96.2 x64 on windows 8.1 x64
Re: 0.96.2 - search dialog : save command missing
click on '+' to save
Gwenael Q.
Hello Pierre,
I have already tried many times the '+' button.
The following dialog opens :
Save search 3.PNG (5.8 KiB) Viewed 1879 times
1. "Search name" is not what I would expect
2. If I enter a name then press OK, I can not find where to call again my saved search ??? the button at the left of the '+' is where I would search for them but there is nothing there !
you click on '+', set a name to save. And after you have it in the combo box to re-apply it
Gwenael Q.
Hello Pierre,
I'm sorry but I keep thinking that saving search is not working at all with my xnviewMp...
By combo-box do you mean the button at the left ot the '+' ? If yes, there is nothing there that is displayed so I can not select any saved search as I already said.
To be sure something is saved or not, could you tell me where are those searches saved and the extension of the file(s) created ?
Thank you !
Gwenael Q.
Hello Pierre,
I suppose my issue is a duplicate of Naming a search does not work
I will wait for version 0.96.3...
Thank you for the work.
Gwenael Q.
This issue is fixed with 0.96.3
Thank you
