XnView crashes in the directory where there is a gimp XCF file present which is saved as grayscale 32 bit.
To reproduce the crash, please create a file in Gimp with the settings, Image --> Mode -> Greyscale, and Image --> Precision -> 32 bit integer or 32 bit floating point. Save the file in a directory, and try to open the directory in XnView. XnView will crash. Tested in XnView 0.9.6 and 0.9.4. Linux.
In Gimp, when the XCF file is changed to Greyscale 16 bit, and saved, XnView will open the folder and show a preview of the file.
(It is probably better to save greyscale images as 16 bit, but it needs to be pointed out that XnView will crash whenever a greyscale 32 bit file is present.)
XnView crashes with greyscale 32 bit XCF
blewbubbles
Re: XnView crashes with greyscale 32 bit XCF
Hi, and sorry but the forum interface wouldn't allow the extension. (EDIT) So I'm sending the file via FilePush. Hope this helps
https://filepush.co/4Zyx/greyscale_32.xcf
The file is saved as stated above. Gimp XCF Greyscale, 32 bit. Thanks.
blewbubbles
Pardon me,
I've done a few more tests and found that the crash is not necessarily caused by the 32 bit greyscale combination as such. I found another image on my desktop that is saved like that, without making Xnview crash, however, it doesn't show a preview, like other multi-layered XCF's. So, when I change this image from greyscale 32 bit, to greyscale 16 bit and save it, this image then makes Xnview crash. Running Xnview from the terminal, it gives the following output from the moment the file, named orion.xcf, is saved with new settings:
############################################ onTimerDirectoryChanged 1
######## checkChildren
############################################ onTimerDirectoryChanged ok
CheckContent...
ThumbLoaderThread :: stop()
### ThumbLoaderThread :: stop() ok
### ThumbLoaderThread :: setFileList(3)
** start condition wake one 2
######ThumbLoaderThread :: forever 2 : 2ac0910
CHECK <0>
######ThumbLoaderThread :: forever : 2ac0910
** start condition wait
CheckContent...
CHECK <1>
### START 3
######ThumbLoaderThread :: start : 1 -1 -1
LOAD BITMAP </home/user/Desktop/astro_images/orion.xcf>
munmap_chunk(): invalid pointer
Aborted
Ok, i can reproduce the crashblewbubbles wrote: Thu Aug 13, 2020 7:13 pm Hi, and sorry but the forum interface wouldn't allow the extension. (EDIT) So I'm sending the file via FilePush. Hope this helps
blewbubbles
Okay, I've tested version 0.96.5 64bits (Aug 18 2020), and now the application doesn't crash when XCF greyscale images are present in the opened directory. Thanks!
