Options' descriptions
marsh
Post by marsh »
Xyzzy wrote:
Xyzzy wrote:I think not only options, but also options tree should be seriuosly rearranged!
As 1.82 is round the corner, I think we can move this project after 1.82, if it is still relevant.
X.
Or with Helmut's assistance- move entire thread to 'general discussion' (or temporary group) except a copy of current option descriptions here. I think the FAQ section would look better that way.
-Beta is arriving now, but most of this might still be relevant.
X.
I've just moved the whole topic. We can copy it (or parts of it) back once there is a final version, but as long as it is under heavy construction, it should not be in FAQ section. I think you understand and agree.
marsh wrote:-Beta is arriving now, but most of this might still be relevant.
Right, most options will be available in 1.82.
Xyzzy
Post by Xyzzy »
marsh wrote:Auto Image Size descriptions:
'Fit image to window, large only'- shrinks image to best fit window/screen
marsh,
I think a lot of explanation is required here. The actual action performed by XnView depends not only on these options, but also on relation of image size to XnView window, Browser window, Viewer window (if General->Use different postion... checked) and desktop size.
One BIG mess :(
X.[/b]
marsh
Post by marsh »
Xyzzy wrote: OK, so Pause works for starting/stopping QSS, but Space only displays next file in View/fullscreen View. Maybe some other setting interferes here?
OK. Only <pause> starts/stops slideshow in v.1.80.3. In older 1.8 versions, both worked. Now in beta1 there is an option for space to start/stop quick slideshow.
Xyzzy wrote: So I am puzzled now. You select this option. Then you go to fullscreen View mode. You single-click left/right mouse button and go to previous/next image?
Here single left click does nothing (click and hold changes pointer into 'panning hand'). Single right click displays context menu.
Either some other option interferes or I am doing something wrong.
BUT works in 1.82 alpha, so maybe it depends on some other setting...?
2 different uses of fullscreen in v.1.80.3 One you can edit, one you cannot. The editable one I refer to as viewer's fullscreen. The non-editable one I refer to as browser's fullscreen or browser+F11. Each behaves differently and can be difficult to document as I'm sure you have already found out. I'm not sure its necessary to document all the differences, since they could be temporary.
Xyzzy wrote: OK, so:
1. These options affect if Items shown in thumbnail mode/other modes can filter files, Use Colour can work, ie allow XnView to properly define file types, yes?
Different file types have predefined colors. These colors also appear in background of thumbnail filename.
Xyzzy wrote: 2. If file is not recognized because of current settings, it is categorised as falling into "All other files" category, yes?
I'm not sure. But you can change font and background color of browser list using windows display settings.
Xyzzy wrote: 3. Recognize...extension checked, Scan...headers- any setting = files are recognized only by extension, Scan...headers option has no effect (effectively files are never scanned OR are scanned as per setting but the scanning result has no effect as for determining file type?)
Scan headers also can work when recognize by extension is also checked. Recognize by extension displays certain files, then those files are scanned.
Onward to the questions:
Xyzzy wrote: Ignore read errors - Read errors during reading image are silently ignored. Are damaged images partially displayed?
I have seen partially downloaded images displayed. I'm not sure that is the same thing though.
Xyzzy wrote: Add XnView to Start menu - ???
Adds Xnview to start menu right above "programs".
Xyzzy wrote: High zoom quality - With this group box you can define operations, for which algorithms producing higher quality images are used. Options refer both to fullscreen and windowed View mode. true?
It only effects viewer in v.1.80.3
marsh
Post by marsh »
Show info icons – If checked, overlays
small info icon on thumbnail frame. Avaliable info icons are: EXIF present,
IPTC present, embedded thumbnail used, image rotated using EXIF info, others?
"Use embedded thumbnails" is also required for its associated icon to be displayed.
Xyzzy
Post by Xyzzy »
Hmm, every info icon is displayed if relevant info is present. So it seems obvious that if Use embedded thumbnails is not checked, info icon for it is not shown because, well, embedded thumbnail is not used.
Anyway, if you check Use embedded thumbnails, info icons for them are not shown for images with no embedded thumbnails.
Is it what you meant?
X.
marsh
Post by marsh »
It is logical as you say, but it wasn't obvious to me at first. Maybe not worth mentioning.
