Text module: can't use "#" symbol
Pumice
Post by Pumice »
Not sure if this needs more description. Using the text module, can't seem to use the # symbol, it results in a "0" placed on the image where the number symbol should be.
For example, a file with the name 123456.jpg:
Item #: {Filename}
Would result in the following text added to the image:
Item 0: 123456
Re: Text module: can't use "#" symbol
'#' is the numeric enumerator, so it's file's index not filename
