Hello, can I set the software to conserve extension for jpeg files because it always change it to jpg.
I use default option for format : "as orginal"
My images arre link to a database so when I try to optimize it, it failed.
C:\Usersxxxxxxxxxx\Sans titre.jpeg 772x854x24 : loaded
C:\Users\xxxxxxxxxxxxx\Sans titre.jpg : saved
C:\xxxxxxxxxxxxxxxe\20190906_155636.jpg 3024x4032x24 : loaded
C:\Uxxxxxxxxxxxxxxxxxx.jpg : saved
thanks for help.
Resize JPEG changes extension to JPG [Solved]
Re: resize JPEG change extension to JPG
sorry for this, it comes from my database that rename the original jpg in jpeg, and xnview just set it in the original format that is jpg, so it's in my hand now.
