Colors for Thumbnails, Overlay Icons size
Re: Colors for Thumbnails, Overlay Icons size
michel038 wrote: Thu Sep 29, 2022 10:32 am Is there a workaround ?
Do you have a [email protected]?
Re: Colors for Thumbnails, Overlay Icons [solved]
Post by michel038 »
XnTriq wrote: Mon Nov 22, 2021 6:30 pm What are the correct dimensions for info.png and [email protected]?
Related bug report: Overlay icon for sidecar files
- info.png is used for Windows display at 100%.
The first one (169 x 11) was probably used for versions 0.97 and older (Pierre's attachment 2020 Nov)
The 2nd one (165 x 15 ) is OK
- [email protected] has to be used when windows display is different from 100% (?)
The "xnviewmp" attachment for [email protected] (316 x 22) seems OK.
Xnview wrote:Do you have a [email protected]?
-Yes now ...., I didn't find this anywhere before re-reading this post, but XnTriq did ...
I'll try it in some days, and provide a coloured version
Post by michel038 »
Windows default scale (100%)
    Image (165×11) from xnviewmp.exe
  • Coloured icons
    (165x11)
Windows display scale at 125%
Create an "icons" folder inside xnviewmp's installation folder.
Copy info.png or [email protected] into this folder.
Restart xnviewmp ...
When using info@2x coloured version, I can see sometimes a rounding error of 1 pixel, but this is not critical ...
( for the forum: screenshot 300% enlargement and jpg quality loss )
Merci beaucoup, michel038 :-) Great post!
I created this SVG file a year ago as proof of concept.
<?xml version="1.0" encoding="UTF-8"?>
<svg xmlns="http://www.w3.org/2000/svg" version="1.1" x="0" y="0" width="316" height="22" viewBox="0 0 316 22" clip-rule="evenodd" fill-rule="evenodd">
<rect fill="lime" width="316" height="22" />
<g>
<path fill="red" d="m0 0l36 0 0 21 -36 0 0 -21zm1 1l34 0 0 19 -34 0 0 -19z" />
<path fill="red" d="m36 0l36 0 0 21 -36 0 0 -21zm1 1l34 0 0 19 -34 0 0 -19z" />
<path fill="red" d="m72 0l29 0 0 21 -29 0 0 -21zm1 1l27 0 0 19 -27 0 0 -19z" />
<path fill="red" d="m101 0l21 0 0 21 -21 0 0 -21zm1 1l19 0 0 19 -19 0 0 -19z" />
<path fill="red" d="m122 0l21 0 0 21 -21 0 0 -21zm1 1l19 0 0 19 -19 0 0 -19z" />
<path fill="red" d="m143 0l21 0 0 21 -21 0 0 -21zm1 1l19 0 0 19 -19 0 0 -19z" />
<path fill="red" d="m164 0l19 0 0 21 -19 0 0 -21zm1 1l17 0 0 19 -17 0 0 -19z" />
<path fill="red" d="m183 0l21 0 0 21 -21 0 0 -21zm1 1l19 0 0 19 -19 0 0 -19z" />
<path fill="red" d="m204 0l33 0 0 21 -33 0 0 -21zm1 1l31 0 0 19 -31 0 0 -19z" />
<path fill="red" d="m237 0l28 0 0 21 -28 0 0 -21zm1 1l26 0 0 19 -26 0 0 -19z" />
<path fill="red" d="m265 0l29 0 0 21 -29 0 0 -21zm1 1l27 0 0 19 -27 0 0 -19z" />
<path fill="red" d="m294 0l22 0 0 22 -22 0 0 -22zm1 1l20 0 0 20 -20 0 0 -20z" />
</g>
</svg>
To give it a try, save the following “code” as [email protected] and copy it to the icons subdirectory of your XnView MP installation.
gonefinishing
Post by gonefinishing »
I wonder what I may have missed here (verified my Windows is at 100% zooming, create the Icons folder, etc.) but, try as I may, I couldn't get this to work.
Is anyone able to help me, please?
Post by michel038 »
Did you create 'icons folder' or 'Icons folder' ?
The right one is without capital letter,
... containing info.png or [email protected]
gonefinishing
michel038 wrote: Sat Sep 09, 2023 5:29 pm Did you create 'icons folder' or 'Icons folder' ?
The thing is it's named exactly 'icons' as it can be seen, with lower-case i, the info.png file inside it and all:
Not having a dodo of what's quite going on yet.
Post by michel038 »
Maybe XnViewMP folder or icons folder is protected by Windows (read/write rights ? or try to open xnviewmp as an admin ? )
Edit 2024/08/30
Since version 1.??, the size of overlay icons was changed...
This is a new version for the info.png file :
Edit 2026/02/04
It seems that since adding the “Number of pages” icon or the second ‘Companion’ icon, my previous image “info.png” no longer works very well.
At least a 12 x 12 pixel square must be added to the right.
