b1: Added : EXIF-user-comment => comment
Locked
Dirk
Post by Dirk »
Editing Metadata / EXIF user comment
http://newsgroup.xnview.com/viewtopic.php?t=4052
Thank you for adding this feature in this short time! :wink:
But at the moment it doesn't work - no Exif User Comments are copied! :bug: (tested with pictures of Canon PowerShot A80)
Dirk
Re: Added : EXIF-user-comment => comment
Dirk wrote:Editing Metadata / EXIF user comment
Could you send me a sample, please?
Dirk
Sample
Post by Dirk »
I sent you one. :)
Re: Sample
Dirk wrote:I sent you one. :)
On @xnview.com?
Dirk
E-Mail
Post by Dirk »
<Mail address has been removed by moderator - please see Rules and Guidelines>
hi Pierre,
yes - I sent it to "<removed>".
You don't get the E-Mail?
Dirk
Re: E-Mail
Dirk wrote:hi Pierre,
Dirk
Ok, i fix it, your EXIF user comment is not standard :-)
Dirk W
bad EXIF
Post by Dirk W »
THANK YOU!!!
Xyzzy
Post by Xyzzy »
Cannot test without image with EXIF user comment set.
X.
Locked
