After clicking a bookmark set focus to file window
MHX
Post by MHX »
With bookmarks you can quickly change to a specific folder.
If you click a bookmark in order to switch to that folder, you most likely want to browse the files in that folder.
Therefore, I suggest to switch the focus to the window part with the files instead of leaving the focus on the bookmark part.
I would like to do this:
- click on a bookmark (folder changes to the chosen one and first picture is automatically selected and shown in preview window)
- press cursor down to go trough the files in the open folder
What I need to do right now:
- click in folder/file pane
- press cursor down key to go trough the files in the open folder
Thanks,
Michael
Re: After clicking a bookmark set focus to file window
the problem is if you use keyboard to navigate to bookmark, focus will be changed too
MHX
Post by MHX »
I would think that this behaviour is wishful for both mouse activated or by keyboard.
Because I think one opens a bookmark in ordner to get to that folder, and then no navigate within that folder, no?
(Or I wish an option for that, in my case I use bookmarks a lot, but I often forget to click again in the folder pane - I am used that the focus switches on itself from old ACDSee 3.1.)
ok, i can add an option by not by default
MHX
Post by MHX »
Great. Thanks!
MHX
Post by MHX »
xnview wrote: Wed Feb 03, 2021 4:10 pm ok, i can add an option by not by default
In the new versions I cannot find the new option, yet. Is it still on your agenda, please?
not yet added
MHX
Post by MHX »
I would still like to see this option.
MHX
Post by MHX »
I installed v1.4.3, but it is not fixed/working.
I click on the bookmark/favorite, then I try to move cursor with keyboard arrows, but as the focus is not in the main window with the files, nothing happens, I cannot go through the files after clicking a bookmark, I still need a further click in the main window.
MHX wrote: Tue Feb 28, 2023 9:04 am I installed v1.4.3, but it is not fixed/working.
Do you have changed in xnview.ini, favSetFocus in [Browser]
ckit
Post by ckit »
xnview wrote: Wed Mar 01, 2023 8:22 am
favSetFocus=true works really well!
TY Pierre 👍
MHX
Post by MHX »
xnview wrote: Wed Mar 01, 2023 8:22 am Do you have changed in xnview.ini, favSetFocus in [Browser]
I had not, as I was not aware about the actual setting to put in the ini file.
I looked in the Settings in all tabs and couldn't find the option, so I assumed that you made it default instead of an option.
I edited xnview.ini and added favSetFocus=true, now it works. Thanks.
