[video attached] Wrong activity when selected folder/file and pressing Shift/Ctrl with Left/Right/PgUp/PgDn/Home/End
forklab
Re: Very strange activity when selected folder/file and pressing Shift/Ctrl with Left/Right/PgUp/PgDn/Home/End
Post by forklab »
xnview wrote: Tue May 06, 2025 3:39 pmIf i understand your video, you have not the same thing?
Yes, if I made the same actions at every machine last action will "select" only last element.
Even if first element is selected.
If I press Right-... (n times) then Home then Shift-End then selection will be starting from the file that was selected after (Right x n) to the end.
And it's only two possible bugs described. In other combinations of keypresses there are more bugs.
user0, I tried everything for the years, if you don't understand this. Clean windows, clean Xnview MP with default settings. Everything.
I recorded a video from my main machine with my settings because I'm using it 24/365 and it has everything I need to record etc.
Explorer works as expected at every machine, no difference is it Win 11 or Win 10.
Only one exception - Xnview MP for ever.
forklab
Post by forklab »
xnview wrote: Tue May 06, 2025 3:39 pm...
- Shift + End, and here all files are selected.
What do you see if you press PgDn after all of this? Is the last file selected only or all files are still selected?
forklab wrote: Tue May 06, 2025 4:59 pm
all files are always selected
I've tried with clean .ini on Win10
I've tried to select first item, right (n times), Home, Shift+End and selection starts from first item
forklab
Post by forklab »
xnview wrote: Wed May 07, 2025 7:34 amall files are always selected
Compare it to standard Explorer behavior (started from first Win 95)
This is the first difference confirmed by you. Maybe it's the start point where XnView selection works not as the Windows Explorer selection.
I understand that you're always, 100%, on "happy path". And some little difference changes everything. For example, all my Win's always has non-default %TEMP% (C:\TEMP) and C:\TEMP is always has RHS attributes. I don't think it's a culprit but something "non default ["noob"] way" makes things much more weird.
At this point I understand that any non-default parameter at Windows or XnView MP leads to this and I try to find a time to start a happy-path (even default en-US interface for Win10 without any libraries (VC, .NET etc), updates, parameters changed like theme (light>dark), sound schemes, background photo (mine is always a black color) and other seemingly insignificant and unimportant things. But it will eat a ton of time to check every possible parameter, each time start XnView MP, try, change parameter, /reboot/, start XnView MP, try... OMG. Really.
forklab wrote: Wed May 07, 2025 12:15 pm
Right here, if i press PgDown, Explorer select the last item not like XnView
But when trying
- left click to remove selection
- Home
- End
- Home
- Shift + End
all files are always selected like Explorer, please send us the xnview.ini
forklab
Post by forklab »
xnview wrote: Wed May 07, 2025 2:50 pmplease send us the xnview.ini
Sent to PM
With your .ini, i have the same behavior on Win10
- Home
- End
- Home
- Shift + End
This problem is supposed to be fixed in XnView MP 1.9.0. Please check and confirm the bug fix here.
