Option to pause GIF file
dev/null
Post by dev/null »
A very useful feature would be the ability to pause GIFs.
Or/and option of moving GIF forward / backward
Re: Option to pause GIF file
you have 'Start/stop animation'
dev/null
Post by dev/null »
OK nice. Is there any keyboard shortcut for this? Or Can I create a shortcut to this option?
dev/null wrote: Thu Mar 25, 2021 12:13 pm OK nice. Is there any keyboard shortcut for this? Or Can I create a shortcut to this option?
you can create a shortcut
dev/null
Post by dev/null »
It works, but still no pause option. After using Start / Stop, the GIF always starts over
It would be great to have an option like pause
dev/null wrote: Fri Mar 26, 2021 11:59 am It works, but still no pause option. After using Start / Stop, the GIF always starts over
you means to pause GIF playing for next loading?
dev/null
Post by dev/null »
xnview wrote: Fri Mar 26, 2021 12:23 pm
No no. I mean pausing the GIF at any time while it is running
My case:
I often record/play GIFs from tutorials with lots of detail or to show the issue in ticket in github repositories
So I would like to pause the GIF at any time to check current content etc. and then play the rest
In other words: something like listening to a song or watching a movie - you want to pause for a moment and then play the rest
By the way:
xnview wrote: Fri Mar 26, 2021 12:23 pm pause GIF playing for next loading?
This would be another useful feature
'Start/stop animation' should not reset animation, but restart at pause position
dev/null
Post by dev/null »
xnview wrote: Thu May 06, 2021 7:41 am 'Start/stop animation' should not reset animation, but restart at pause position
Oh, it doesn't work that way for me
Let me show you an example: https://i.imgur.com/wTeGeI4.gif
As you can see, after use "Start / Stop Animation" it start from beginning, not from pause position
The GIF I'm testing is available here: https://i.imgur.com/I6YnS0A.gif
dev/null wrote: Thu May 06, 2021 8:21 am Oh, it doesn't work that way for me
yes :) i confirm as a :bugconfirmed:
This problem is supposed to be fixed in XnView MP 0.99.0. Please check and confirm the bug fix here.
dev/null
Post by dev/null »
Works fine. Thank you!
