A strange file that creates .bak when categorized [solved]
Post by michel038 »
My settings for metadata:
Export categories to subject xmp and iptc keywords are enabled.
I select the file Ponsonas2.jpg, and mark a category.
- The keywords are updated
- A new file Ponsonas2.jpg.bak is created. :shock:
If I move the file to another folder, the problem remains.
If I resize the file and save it as, the problem remains
This file is the only one to have this behaviour :!: :?:
If I download this file from the forum, I can't reproduce the problem
However, I can't see any difference between the original file and the downloaded file
Re: A strange file that creates .bak when categorized [solved]
Post by michel038 »
The file was write protected :mrgreen: :(
sorry
I still do not understand how can XnViewMP write keywords in a read only file ...
