Add option "Reduce filesize to..." [SUGGESTION]
Титан
Post by Титан »
Hello! Thank you very much for your applications! Can you add the option "reduce filesize to ►" and the list of sizes, including 100kb, 200kb, 500kb, 1MB, 2MB and 5Mb (and something else)?
How it will work? Easy – if it's a lossy format, XnShell will make compression as high to match the defined size. If not – lowering video/image resolution.
That thing is realized in Paint.net.
