The "keep ratio" is not saved after a resize
mulanee
Re: The "keep ratio" is not saved after a resize
Post by mulanee »
xnview wrote: Thu Jul 08, 2021 1:02 pm it works here, are you use that you have rights to write xnview.ini?
I am admin so I have the rights.
I tried to edit/modify/save the xnview.ini without any problem
By forcing the option in the .ini it works but this is just a workaround
Emmanuel
mulanee
Post by mulanee »
Finally I found out.
In parameter/system integration/integration, it has to be in register, not in ini in the folder
Emmanuel
