0.99.1: Typographical mistakes
Fleet Command
Post by Fleet Command »
XnView: MP 0.99.1
OS: Windows
There are several typographical mistakes in the "Settings → File list → Customer filter" section of XnViewMP. I will list them below, along with their correct form.
Effect: Typographical mistakes reduce an app's prestige, but have no functional impact.
  1. Install XnViewMP 0.99.1 and start it.
  2. From the Tools menu, select "Settings..." (or just press F12.)
  3. On the left-hand side, select the "File list" item.
  4. On the right-hand side, ensure that the "Custom filter" tab is selected.
Actual behavior (bug):
  1. On the first column, the third item from the bottom reads, "All others files." It must be "all other files." ("Other" is an adjective.)
  2. In the Extensions column, the "Video" row:
    • M4A and MPA are mistakenly listed as videos.
      These are audio files and belong to the "Audio" row. (Additional suggestion: Please add M4B to the audio row too.)
    • 3GP, 3GP2, and 3G2 are mistakenly listed under the QuickTime section. In reality, they are derived from MPEG-4 Part 12.
      For more information, see "3GP and 3G2" on English Wikipedia.
    • VOB is mistakenly listed under "AVI". It is an MPEG format.
      For more information, see "VOB" on English Wikipedia.
    • WMV and ASF are mistakenly listed under AVI.
      AVI was a 1st-generation Microsoft format. WMV and ASF are 2nd-generation Microsoft formats. I suggest renaming the "AVI" label to "Microsoft."
