Viewer ratings not shown in Browser
mrsmahersbar
Re: Viewer ratings not shown in Browser
not sure how to drop in a photo, but under Rating & Label, neither box is checked.
mrsmahersbar
Yes it is.
mrsmahersbar
How do I locate that? I tried googling the answer but there is nothing in my program files labeled with .ini
Settings>Integration>Pathsmrsmahersbar wrote: Sat Oct 21, 2023 10:53 am How do I locate that? I tried googling the answer but there is nothing in my program files labeled with .ini
mrsmahersbar
It works with your ini, i open a folder with 2 files. Double click on first to go in viewer mode, i rate it, and go to next, rate it. Close viewer, and in browser i can see rating...mrsmahersbar wrote: Sun Oct 22, 2023 11:05 am https://docs.google.com/document/d/1nsO ... sp=sharing
Do you rate jpeg files?
mrsmahersbar
I am rating RAW files straight off of my camera card.
mrsmahersbar
I recorded my screen to show how the ratings don't stick in the browser screen. I've been using CTRL+1 to rate. I've been using this method for a handful of years now so it's very strange that it just stopped working out of the blue in the middle of culling a session.
https://drive.google.com/file/d/11zjPF- ... share_link
ETA: I ended up importing the photos off the camera card into a folder and trying again, and it seems to be working again... I guess working off the card directly got glitchy. Thanks so much for trying to help me fix it!
