Update rating from files
thunder-flip
Post by thunder-flip »
Subject: 0.99.6: "update catalog from files" don't update ratings
XnView: MP 0.99.6 64bits (Dec 10 2021)
OS: Windows 10 - 64 bits
No refresh of ratings made outside XnView
Effect: Difficulty to modify image's ratings from differents applications or on a shared directory
  • Create a catalog
  • Import a directory in the newly created catalog
  • Modifiy rating of one of theses images from Windows Explorer for example (add a star)
  • Select modified image in XnView
  • Refresh catalog from files
Actual behaviour (bug): rating isn't updated
Expected behaviour: new rating should appear on modfied images
thunder-flip
Re: Update rating from files
It's maybe linked with that problem solved in next version : https://www.xnview.com/mantisbt/view.php?id=2248
no not the same problem. You change the rating in windows explorer, and 'Update catalog from files' don't update rating in XnView?
thunder-flip
I tried on the new version 0.97. It worked.
You can close the topic.
