Application is unresponsive when browsing network share
greatvovan
Re: Application is unresponsive when browsing network share
Sounds great. Please let me know if I can assist you.
after some tests, on a SMB shared folder with 4000 subfolders, i have big delay to browser in Wifi, but with direct LAN the delay is less than 500ms
greatvovan
Well, thats great, though I have a few points here:
1. I tried it with a wire connection, but I did not notice any significant difference in performance, the lags remain huge and UI is glitchy.
2. Like I said earlier, other file browsing applications (including ones that show thumbnails) work reasonably fast.
3. Interestingly, in a virtual machine running on the same computer I installed XnView MP for Windows and it worked much better with the same network share! No UI glitches, the browsing speed is reasonable.
I think the above points give enough evidence that the issue is not related to my network connection or slow NAS, but it is rather the application itself. I am happy to run more tests if it helps to investigate the issue.
I've sent you a PM to try a debug version...greatvovan wrote: Sun Feb 27, 2022 5:10 am 1. I tried it with a wire connection, but I did not notice any significant difference in performance, the lags remain huge and UI is glitchy.
Stone-D
Could you please port the fix to XnView Classic?
