B1: Allow resizing of selection also with LMB
Locked
Dreamer
Post by Dreamer »
Another attempt... Link to original request (with no reply) -
Allow resizing of selection also with LMB.
I must use LMB to move the scrollers and then I press LMB also when I resize a selection, by mistake and then I lose it, it's very annoying. It should be easy to implement, so please try to check it out. Thanks.
Re: B1: Allow resizing of selection also with LMB
Dreamer wrote:Another attempt... Link to original request (with no reply) -
Ok
Dreamer
Post by Dreamer »
Ok
Thanks. :)
Xyzzy
Post by Xyzzy »
Fixed in b2. Used RMB to make selection and then LMB to move/resize it.
X.
Dreamer
Post by Dreamer »
Confirmed, thanks Pierre. :)
Locked
