Self-assigned icons in toolbar displayed wrong
Bezier
Post by Bezier »
It seems that when assigning an icon to a toolbar function, this self-assigned icon is treated differently from the ones pre-assigned: It is smaller and has a colored background.
- Tools / Settings / Interface / Toolbar
- View mode
- Add "Fit image to window, large only" to toolbar
- Set Icon to XNView's own icons-48/cmd_zoom100.png
Expected result: The two "Zoom 100%" icons in the toolbar look the same.
Observed result: see attached screenshot.
XnViewMP 0.99.7 64 bit; Windows 10 20H2
(similar effect is observed under Linux Mint)
Best regards,
Bezier
Re: Self-assigned icons in toolbar displayed wrong
XnView MP has 2 versions of icons (24x24 & 48x48), so you can have difference with the 48x48 version
Bezier
Post by Bezier »
Thanks, Pierre.
Given that I use small icons, that let me create one that looks just like the others :)
But it still shows the blue background after startup, or after clicking on it. Just a minor cosmetic issue, of course.
Best regards,
Bezier
"View>Image file>Fit image to window, large only" is checked?
I've just tried the steps in the original post and could reproduce the problem:
When clicking on the added icon the background is blue and remains blue until zoom changes. So the background of the icon isn't permanently blue but only right after clicking on it and until you change the zoom (e.g. by using Ctrl+Mouse wheel).
Perhaps this blue background of the icon is used to indicate that "Fit image to windows, large only" is active? But then, the "Zoom 100%" icon hasn't got this blue background when clicking on it. So there is something wrong.
helmut wrote: Thu Mar 03, 2022 5:06 am Perhaps this blue background of the icon is used to indicate that "Fit image to windows, large only" is active? But then, the "Zoom 100%" icon hasn't got this blue background when clicking on it. So there is something wrong.
"Fit image to windows, large only" is like a choice between other fit mode, so selected. Zoom 100% is an action, 'Fit mode' is not changed
Bezier
Post by Bezier »
xnview wrote: Wed Mar 02, 2022 8:16 am "View>Image file>Fit image to window, large only" is checked?
Yes, it's checked.
I understand. As a matter of fact, when clicking on "Zoom 100%", "Zoom +", or "Zoom -", "Fit image to windows, large only" is changed (unchecked in menu, no blue background in toolbar). But I'd say it makes sense this way because once an explicit zoom is applied, the image does indeed not fit to the window anymore.
So it's not a bug but intended behavior, though somewhat confusing for someone who doesn't know XnViewMP as well as you do.
Thanks again for your support; issue can be closed.
Best regards,
Bezier
Thank you for your reply, Bezier. Problem reproduced (thank you for the detailed problem report), tracked down, analyzed, and solved. :)
