Reproducable bug: V. 1.0 beta crashes
On both WIndows 10 computers on which I installed the recent beta 1.0, XnViewMP closes without warning as soon as I choose a category in order to filter my pictures. This happens exceptionally always.
Olympus OMD E-M1, BS Kinetics underwater housing, 2xSubtronic pro 160 flashes. Zuiko mFT lenses: 60 macro, 7-14, 8 mm fisheye, 12-100, PanaLeica 100-400.
My Homepage | My book at Amazon
Re: Reproducable bug: V. 1.0 beta crashes
Have you tried the new XnView MP 1.00 beta 1 version, in case this has already been fixed?Tschens wrote: Mon Apr 04, 2022 12:58 pm On both WIndows 10 computers on which I installed the recent beta 1.0, XnViewMP closes without warning as soon as I choose a category in order to filter my pictures. This happens exceptionally always.
Yes I also have this problem even with v1.0 Beta 1
could you send me your xnview.db/thumb.db, and tell me which category do you try to see?
No problem when browsing folder? Back to 0.99.7 no problem?
I don't have my "PC photo" under the hand currently.
But for info, this happens on all photos and any category.
I think the beta uses the same database as XNViewmp 0.99.7 that works properly.
I tested on 2 pc and the bug is fixed.
thanks
thanks
beta 2: Problem solved, tested on 2 PCs with Windows 10.
