Face tag plugin & auto exif rotation [solved]
Post by michel038 »
Check this option : Settings > General > "Rotate images according to EXIF orientation tag"
For photos that are not in natural orientation :
- When the option is enabled, the Face tag plugin can detect faces, but displays wrong regions.
- If the option is disabled, rotated faces are not detected
(in this case, we can manually define regions and add names)
Re: Face tag plugin & auto exif rotation
Post by michel038 »
I try uploading sample files here
This first photo for a reference : Orientation landscape,
- detection and regions OK in all cases
This photo needs a 90° clockwise rotation. (Internet browsers automatically rotates)
Download the photo and browse with Xnviewmp ...
1) Disable rotation according to exif
- No face detection. It is not surprizing.
- user defined regions : all OK
2) Enable exif auto rotation
Face detection ok, but wrong place for regions :bug:
-user defined regions : wrong place for regions :bug:
:bugconfirmed: Thanks to your detailed description I can reproduce the problem. It will be fixed in beta 3
Post by michel038 »
V1 Beta 3
Tests ok on 4 different exif rotations.
Fixed 8)
quick and effective !
