XnView: MP 1.00 beta3 - 64 bit
OS: Windows 10
In ZIP archives only limited functionality is possible. Many features in XnView (e.g. tagging, categories, ...) remain enabled but just have no effect.
Effect: Unintuitive/wrong behaviour.
1. Download the ZIP archive "Numbers-Ratings.zip" attached to this topic and save it on a local drive. Do not unpack it.
2. Start XnView MP and browse the archive.
3. Double-click on thumbnail of subfolder "Numbers". --> Subfolders "A", "B", "C" and files "1" and "9" are shown.
4. Assign rating "Poor" to the image.
5. Switch to panel "Categories Filters".
6. Select rating "Poor".
Actual behaviour (bug): Rated image that is located in ZIP archive is not shown.
Expected behaviour: Consistent behaviour, e.g. disable tags, ratings, and all the functionality that is not supported within ZIP archives.
1.0 b3: ZIP archive: Non-supported functionality not disabled
- Attachments
- Numbers-Ratings.zip
- (20.1 KiB) Downloaded 19 times
Re: 1.0 b3: ZIP archive: Non-supported functionality not disabled
Just tried in 1.00 beta 4. Most functionality is disabled and it's much better, now. Though, when left-clicking with the mouse on the top-left spot where star rating is set, the context menu with menu items "Unrated", "Poor", and so on is opened.
will be fixed in final release...
