XnView MP and Photoshop *.ACR files.
FKCapitalism2
Re: XnView MP and Photoshop *.ACR files.
Post by FKCapitalism2 »
Still facing lots of issues and confusion with how XnViewMP handles sidecars.
When i assign Photoshop to Open With (Alt+1) menu and start it with on 007.ARW then it creates sidecar 007.XMP.
1. However that 007.XMP is only used when i use Open With (Alt+1) from XnViewMP menu, if i open using Photoshop > File > Open and select 007.ARW it does NOT load 007.XMP automatically as it should.
2. If Photoshop > File > Open used then changes made to 007.ARW in Adobe Camera Raw then it saves new sidecar file 007.arw_xmp because file 007.XMP already exists.
Pinpointed the problem its because when opening 007.ARW with Open With (Alt+1) and save changes then inside 007.XMP it adds line
photoshop:SidecarForExtension="ARW "
space after "ARW ", this is reason it never being auto loaded from Photoshop Photoshop > File > Open
If Photoshop > File > Open then save XMP it will have
photoshop:SidecarForExtension="ARW"
no space after "ARW", then XMP loads properly when opening from Photoshop > File > Open and select 007.ARW
From what i understand when opening one file in XnViewMP using Alt+1 then it adds spaced "ARW " to that file's XMP, however if opening multiple files in XnViewMP then it adds spaced "ARW " only to the last file in series, must be something in part of source that supply file path or file name to external program.
FKCapitalism2 wrote: Sun Oct 05, 2025 11:04 am Pinpointed the problem its because when opening 007.ARW with Open With (Alt+1) and save changes then inside 007.XMP it adds line
photoshop:SidecarForExtension is added by which app?
FKCapitalism2
xnview wrote: Mon Oct 06, 2025 8:55 am
Its added by Photoshop's Adobe Camera RAW plugin when saving settings after editing ARW file it creates XMP with this settings.
However i assume the file path depends on the path that XnViewMP provides to the Photoshop there must be trailing space somewhere.
FKCapitalism2
My old command looked like this note -NoSplash argument, but any argument can cause this problem...
...because last filenames supplied has trailing space "C:\Program Files\Adobe\Adobe Photoshop 2026\Photoshop.exe" "D:\01.arw" "D:\02.arw" "D:\03.arw" -NoSplash" note the space between "D:\03.arw" -NoSplash.
somehow Photoshop understands this command like this uses "D:\03.arw " (space after extension.
Can't fix in XnViewMP as if i change order of command it does not open files in Photoshop just launching the program "C:\Program Files\Adobe\Adobe Photoshop 2026\Photoshop.exe" -NoSplash "D:\01.arw" "D:\02.arw" "D:\03.arw" -NoSplash" .
So only fix is to remove all the arguments from XnViewMP's Configure programs dialog.
Then after saving changes in Photoshop - Adobe Camera Raw creates .xmp sidecar file with proper command photoshop:SidecarForExtension="ARW" instead of photoshop:SidecarForExtension="ARW "
