Installer beta
Locked
dickymoe
Installer beta
Post by dickymoe »
Hello, i'd like known (it's no very english but i'm french)... why are no installer for the beta version ?
An installer, it's good, for exemple name the beta version on xnviewbeta and this one no overwrite the stable version !!
It's better than a zip I think...
No ?
Separate dir !
:) Hello, bonjour !
- It's better to install the test-version in another separate directory, that I do always…
- So, it's more flexible to change only the needed items along the advancement of the tests…
- Working such as, an installer is useless…
:mrgreen: Kind regards,
{ Aside : BTW, there is a French forum here ;) }
Dreamer
Re: Installer beta
Post by Dreamer »
dickymoe wrote:Hello, i'd like known (it's no very english but i'm french)... why are no installer for the beta version ?
No ?
I don't think so. You can unzip xnview anywhere you want, you can also rename it, so if you have XnView stable in "C:\Program Files\XnView", you can unzip XnView beta, rename to XnView beta and move to "C:\Program Files\XnView beta", no need to install anything. You can even copy your xnview.ini settings file to beta dir.
Post by Guest »
Yes but it's more easy and speed...
ckv
Post by ckv »
Anonymous wrote:Yes but it's more easy and speed...
Easy? You mean clicking nex buton is easy? Speed? Well if you just click the nex then it just might be faster... naah zip is still faster.
XnView don't install any runtime components or don't need to create any registery entrys in order to work. So why beta versions should be published in installers?
Xyzzy
Post by Xyzzy »
Close. Non-issue.
X.
Locked
