1.3.1 archive files in detail mode
fletchni
Re: 1.3.1 archive files in detail mode
Post by fletchni »
Hi - not sure whether to report a new bug or if this one in this thread is exactly the same:
  • Mac OS (Ventura)
  • XnView MP for Mac 1.31
Cannot view / browse any Zip files with .jpg images inside - in any mode, but I mostly use Thumbnails & Filenames:
  • Zip file gets open in and read and the view moves into that "folder" (i.e. zip file).
  • But no preview and not able to open
  • Just lists each file as a white placeholder - but with the file name
Because my file was on a network and Pierre mentioned something about moving the folder to the desktop (albeit Windows and not Mac), I tested with a local zip file and even copied one of the failing network zip files to a local folder and same result - not able to preview or open the images inside.
I reverted to 1.30 and all is fine (I actually went back and forward to 1.31 a few times just to check it wasn't me).
Thanks!
This problem is supposed to be fixed in XnView MP 1.4.0. Please check and confirm the bug fix here.
