b2: Maximize view when open problem
Locked
Xyzzy
Post by Xyzzy »
Hello!
If Force XnView to Fit Image is checked, Maximize view when open does not work.
If Force... is checked and Maximize... is not, image is opened in maximized window, should not.
Remember, that this option (Maximize...) works only for windowed View run directly from Windows.
X.
Re: b2: Maximize view when open problem
Xyzzy wrote:If Force XnView to Fit Image is checked, Maximize view when open does not work.
Really, when i open a picture, i have it maximized...
Yes, it's normal, if view window is not maximized, how can i resize main window??
Xyzzy
Post by Xyzzy »
This is how it looks like:
and this is how it should:
X.
Danny
Post by Danny »
Tabs and windows don't work too well together yet. Does it happen with tabs completely disabled?
Xyzzy
Post by Xyzzy »
It works improperly also if 'Hide tab if only one window is opened' is checked.
This options (Maximize view when open) should be removed if it cannot be made to work.
X.
Xyzzy wrote:It works improperly also if 'Hide tab if only one window is opened' is checked.
X.
I disagree. Remember that XnView is an MDI application. "Maximize view when open" does nothing else than maximizing the child window when opening an image view. This works o.k. and in no case must be removed.
Xyzzy
Post by Xyzzy »
Problem is that it is always maximized.
So an option to turn off maximizing is useless.
X.
Xyzzy wrote:Problem is that it is always maximized.
X.
Right, for most people child windows are always maximized. But there might be people still using MDI and it's child windows and working with non-maximized windows. Not sure, though.
Xyzzy
Post by Xyzzy »
As far as I know this option only affects only windowed View run directly from Windows. It does not affect opening from Browser.
So it can be removed, as View opened from Windows is always maximized.
X.
Xyzzy wrote:As far as I know this option only affects only windowed View run directly from Windows. It does not affect opening from Browser.
Please try this and you will see that it does not affect windowed view run directly from Windows:
1. Uncheck option "Maximize view when open"
2. Un-maximize XnView browser
3. Double-click on a thumbnail to open image view
--> Window for image view is opened, non-maximized.
Xyzzy
Post by Xyzzy »
Helmut, but there is no damn hint anywhere that I have to restore Browser window for this to work. Another development problem made a part of "design"...
With regard to http://newsgroup.xnview.com/viewtopic.php?t=4311 I Close this one.
X.
Locked
