1.4.0b1 - Categories import no longer handles subcategories
ReefHound
Post by ReefHound »
Steps to reproduce
1. Open XnView
2. Select a layout that displays Categories pane
3. Select a file so pane is enabled.
4. Select the drop arrow at upper right, then Categories Management, then Clear All to clear categories
5. From Categories Management, select Import from file and select a file with indented (nested) categories.
In 1.3.1 the indented lines imported as nested subcategories, per screenshot
In 1.4.0b1 the indented lines imported as flat parent categories, per screenshot
Example categories file with nested subcategories
(it looks like the forum strips out whitespace so I can't show it indented nor can I attach a text file. I added asterisks to denote indents. Two asterisks denote 2 levels of indenting. I just shortened the list. You don't need that many to get the point.)
Author
*author1
*author2
xClass
*101
*xSubClass
**101
**102
xType
*A
*B
Xnview cat 131 Screen Shot.JPG (78.64 KiB) Viewed 595 times
Xnview cat 141 Screen Shot.JPG (71.33 KiB) Viewed 595 times
Re: 1.4.0b1 - Categories import no longer handles subcategories
right will be fixed in beta 2
ReefHound
Post by ReefHound »
Confirmed fixed in 1.4.0 ,Dec 12
