Settings - catalog - group thumbnail caching settings | move uom out of control
XnViewMP 1.3.1 64bit
Windows10 64bit (22H2), display resolution 3840x2160, win scaling 150%
Settings - Catalog
Suggestion A
  • Move 'Maximum size for cached thumbnails' into 'Enable thumbnail caching' group and enable/disable it accordingly
Suggestion B
  • Remove units of measure from the numeric fields for:
    - better readability and
    - general UI consistency (have not seen this approach in the app anywhere else)
Suggestion C
  • limit memory usage to 2Gb max, as 99.99Gb or RAM is a bit too much
Related
Re: Settings - catalog - group thumbnail caching settings | move uom out of control
done in 187
