If there are just these extensions in folder, 4 folder thumbnails are missing:
ani, ico, wmf
There might be more such extensions, add here if you find some, please.
B2: 4 folder thumbnails missing for more extensions
OK, but use your old topic please, if it's already in "Closed/Solved.." forum, I could move it back to "New..".robc wrote:As I said elsewhere, all video files do not show in 4 in 1 folders; Pierre said that it is by design, so be it, but I believe that if a file (whatever type it is) is thumbnailed, then it should also show in the 4 in 1, at least to give users an uniform interface.
Re: B2: 4 folder thumbnails missing for more extensions
.jpeg doesn't work either.Dreamer wrote:If there are just these extensions in folder, 4 folder thumbnails are missing:
ani, ico, wmf
Right, reported before, should be fixed in the next beta.CK wrote:.jpeg doesn't work either.
